await QueuedTask.Run(() =>
if (voxelLayer.Visualization != VoxelVisualization.Volume)
voxelLayer.SetVisualization(VoxelVisualization.Volume);
voxelLayer.SetSliceContainerExpanded(true);
voxelLayer.SetSliceContainerVisibility(true);
//To stop the Voxel Exploration Dockpane activating use:
voxelLayer.AutoShowExploreDockPane = false;
//This is useful if u have your own dockpane currently activated...
//Use the SelectedVariableProfile to get the slices currently in the TOC
//via its associated volume
var volume = voxelLayer.SelectedVariableProfile.Volume;
var volumeSize = volume.GetVolumeSize();
//Orientation 90 degrees (West), Tilt 0.0 (vertical)
//Convert to a normal
var normal = voxelLayer.GetNormal(90, 0.0);
//Create the slice at the voxel mid-point. VoxelPosition
//is specified in voxel-space coordinates
//Create the slice on the respective volume
volume.CreateSlice(new SliceDefinition()
Name = "Middle Slice",
VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
Normal = normal,
IsVisible = true
//reset if needed...
voxelLayer.AutoShowExploreDockPane = true;
//Normally, it would be set in your dockpane
var slice = volume.GetSlices().First(s => s.Name == "Change Tilt Slice");
(double orientation, double tilt) = voxelLayer.GetOrientationAndTilt(slice.Normal);
//Convert orientation and tilt to a normal
slice.Normal = voxelLayer.GetNormal(orientation, 45.0);
volume.UpdateSlice(slice);
//reset if needed...Normally this might be when your dockpane
//was de-activated (ie "closed")
if (voxelLayer.Visualization != VoxelVisualization.Surface)
voxelLayer.SetVisualization(VoxelVisualization.Surface);
voxelLayer.SetSectionContainerExpanded(true);
voxelLayer.SetSectionContainerVisibility(true);
//Create a section that cuts the volume in two on the vertical plane
//Use the SelectedVariableProfile to get the sections
//Orientation 90 degrees (due West), Tilt 0 degrees
//Position must be specified in voxel space
volume.CreateSection(new SectionDefinition()
Name = "Middle Section",
Normal = normal,
IsVisible = true
