public Coordinate3D Normal {get; set;}
Public Property Normal As Coordinate3D
await QueuedTask.Run(() =>
if (voxelLayer.Visualization != VoxelVisualization.Surface)
voxelLayer.SetVisualization(VoxelVisualization.Surface);
voxelLayer.SetSectionContainerExpanded(true);
voxelLayer.SetSectionContainerVisibility(true);
//To stop the Voxel Exploration Dockpane activating use:
voxelLayer.AutoShowExploreDockPane = false;
//This is useful if u have your own dockpane currently activated...
//Normally, it would be set in your dockpane
//Create a section that cuts the volume in two on the vertical plane
//Use the SelectedVariableProfile to get the sections
//via its associated volume
var volume = voxelLayer.SelectedVariableProfile.Volume;
var volumeSize = volume.GetVolumeSize();
//Orientation 90 degrees (due West), Tilt 0 degrees
var normal = voxelLayer.GetNormal(90, 0.0);
//Position must be specified in voxel space
volume.CreateSection(new SectionDefinition()
Name = "Middle Section",
VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
Normal = normal,
IsVisible = true
//reset if needed...Normally this might be when your dockpane
//was de-activated (ie "closed")
voxelLayer.AutoShowExploreDockPane = true;
//180 degrees orientation is due South. 90 degrees orientation is due west.
var south = 180.0;
var num_sections = 12;
var spacing = 1 / (double)num_sections;
//Create a section every nth degree of orientation. Each section
//bisects the middle of the voxel
for (int s = 0; s < num_sections; s++)
var orientation = south * (s * spacing);
Name = $"Circle {s + 1}",
Normal = voxelLayer.GetNormal(orientation, 0.0),
IsVisible = true
//Make three Normals - each is a Unit Vector (x, y, z)
var north_south = new Coordinate3D(1, 0, 0);
var east_west = new Coordinate3D(0, 1, 0);
var horizontal = new Coordinate3D(0, 0, 1);
int n = 0;
//The two verticals bisect the x,y plane. The horizontal normal bisects
//the Z plane.
foreach (var normal in new List<Coordinate3D> { north_south, east_west, horizontal })
Name = $"Cross {++n}",
Normal = normal,
IsVisible = true
//make a diagonal across the voxel
var voxel_pos = new Coordinate3D(0, 0, volumeSize.Z);
var voxel_pos_ur = new Coordinate3D(volumeSize.X, volumeSize.Y, volumeSize.Z);
var lineBuilder = new LineBuilderEx(voxel_pos, voxel_pos_ur, null);
var diagonal = PolylineBuilderEx.CreatePolyline(lineBuilder.ToSegment());
//change as needed
var orientation = 20.0; //(approx NNW)
var tilt = -15.0;
var normal = voxelLayer.GetNormal(orientation, tilt);
Coordinate2D end_pt = new Coordinate2D(0, 0);
if (s > 0)
//position each section evenly spaced along the diagonal
var segments = new List<Segment>() as ICollection<Segment>;
var part = GeometryEngine.Instance.GetSubCurve3D(
diagonal, 0.0, s * spacing, AsRatioOrLength.AsRatio);
part.GetAllSegments(ref segments);
end_pt = segments.First().EndCoordinate;
Name = $"Diagonal {s + 1}",
VoxelPosition = new Coordinate3D(end_pt.X, end_pt.Y, volumeSize.Z),
Normal = normal,
IsVisible = true
foreach (var section in volume.GetSections())
//set each normal to 45.0 orientation and tilt
section.Normal = voxelLayer.GetNormal(45.0, 45.0);
//apply the change
volume.UpdateSection(section);
