ArcGIS.Desktop.Mapping.Voxel Namespace / SliceDefinition Class / IsVisible Property
Example
    IsVisible Property (SliceDefinition)
    Gets and sets whether the slice is visible.
    Syntax
    public bool IsVisible {get; set;}
    Public Property IsVisible As Boolean
    Example
    Get the Collection of Slices
      await QueuedTask.Run(() =>
        //Use the SelectedVariableProfile to get the slices currently in the TOC
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        var slices = volume.GetSlices();
        //Do something... e.g. make them visible
        foreach (var slice in slices)
          slice.IsVisible = true;
          volume.UpdateSlice(slice);
        //expand the slice container and make sure container visibility is true
        voxelLayer.SetSliceContainerExpanded(true);
        voxelLayer.SetSliceContainerVisibility(true);
    Create a Slice
        if (voxelLayer.Visualization != VoxelVisualization.Volume)
          voxelLayer.SetVisualization(VoxelVisualization.Volume);
        //To stop the Voxel Exploration Dockpane activating use:
        voxelLayer.AutoShowExploreDockPane = false;
        //This is useful if u have your own dockpane currently activated...
        var volumeSize = volume.GetVolumeSize();
        //Orientation 90 degrees (West), Tilt 0.0 (vertical)
        //Convert to a normal
        var normal = voxelLayer.GetNormal(90, 0.0);
        //Create the slice at the voxel mid-point. VoxelPosition
        //is specified in voxel-space coordinates
        //Create the slice on the respective volume
        volume.CreateSlice(new SliceDefinition()
          Name = "Middle Slice",
          VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
          Normal = normal,
          IsVisible = true
        //reset if needed...
        voxelLayer.AutoShowExploreDockPane = true;
    Requirements
