ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVariableProfile Class / DataType Property
Example
    DataType Property (VoxelVariableProfile)
    Gets the variable profile's data type. Data can be continuous or discrete.
    Syntax
    public VoxelVariableDataType DataType {get;}
    Public ReadOnly Property DataType As VoxelVariableDataType
    Example
    Get the Variable Renderer
      var variable = voxelLayer.GetVariableProfiles().First();
      var renderer = variable.Renderer;
      if (variable.DataType == VoxelVariableDataType.Continuous)
        //Renderer will be stretch
        var stretchRenderer = renderer as CIMVoxelStretchRenderer;
        //access the renderer
      else //VoxelVariableDataType.Discrete
        //Renderer will be unique value
        var uvr = renderer as CIMVoxelUniqueValueRenderer;
    Access Stats and Color Range for a Stretch Renderer
      //Get the variable profile on which to access the data
      var variable = voxelLayer.SelectedVariableProfile;
      //or use ...voxelLayer.GetVariableProfiles()
      //Data range
      var min = variable.Statistics.MinimumValue;
      var max = variable.Statistics.MaximumValue;
      //Color range (Continuous only)
      double color_min, color_max;
        var renderer = variable.Renderer as CIMVoxelStretchRenderer;
        color_min = renderer.ColorRangeMin;
        color_max = renderer.ColorRangeMax;
    Change Stretch Renderer Color Range
      //Typically, the default color range covers the most
      //commonly occurring voxel values. Usually, the data
      //range is much broader than the color range
      await QueuedTask.Run(() =>
        //Get the variable profile whose renderer will be changed
        //Check DataType
        if (variable.DataType != VoxelVariableDataType.Continuous)
          //must be continuous to have a Stretch Renderer...
        var color_min = renderer.ColorRangeMin;
        var color_max = renderer.ColorRangeMax;
        //increase range by 10% of the current difference
        var dif = (color_max - color_min) * 0.05;
        color_min -= dif;
        color_max += dif;
        //make sure we do not exceed data range
        if (color_min < variable.Statistics.MinimumValue)
          color_min = variable.Statistics.MinimumValue;
        if (color_max > variable.Statistics.MaximumValue)
          color_max = variable.Statistics.MaximumValue;
        //variable.Statistics.MinimumValue
        renderer.ColorRangeMin = color_min;
        renderer.ColorRangeMax = color_max;
        //apply changes
        variable.SetRenderer(renderer);
    Change The Visibility on a CIMVoxelColorUniqueValue class
        //Check DataType
        if (variable.DataType != VoxelVariableDataType.Discrete)
          return;//must be Discrete to have a UV Renderer...
        var renderer = variable.Renderer as CIMVoxelUniqueValueRenderer;
        //A CIMVoxelUniqueValueRenderer consists of a collection of
        //CIMVoxelColorUniqueValue classes - one per discrete value
        //in the associated variable profile value array
        //Get the first class
        var classes = renderer.Classes.ToList();
        var unique_value_class = classes.First();
        //Set its visibility off
        unique_value_class.Visible = false;
        //Apply the change to the renderer
        renderer.Classes = classes.ToArray();
        //apply the changes
    Check a Variable's Datatype
        //No iso surfaces
        //Iso surface can only be created for VoxelVariableDataType.Continuous
    Requirements
