public VoxelAssetEventArgs.VoxelAssetChangeType ChangeType {get;}
Public ReadOnly Property ChangeType As VoxelAssetEventArgs.VoxelAssetChangeType
MapMemberPropertiesChangedEvent.Subscribe((args) =>
var voxel = args.MapMembers.OfType<VoxelLayer>().FirstOrDefault();
if (voxel == null)
return;
//Anything changed on a voxel layer?
if (args.EventHints.Any(hint => hint == MapMemberEventHint.VoxelSelectedVariable))
//Voxel variable profile selection changed
var changed_variable_name = voxel.SelectedVariableProfile.Variable;
//TODO respond to change, use QueuedTask if needed
else if (args.EventHints.Any(hint => hint == MapMemberEventHint.Renderer))
//This can fire when a renderer becomes ready on a new layer; the selected variable profile
//is changed; visualization is changed, etc.
var renderer = voxel.SelectedVariableProfile.Renderer;
VoxelAssetChangedEvent.Subscribe((args) =>
//An asset changed on a voxel layer
System.Diagnostics.Debug.WriteLine("");
System.Diagnostics.Debug.WriteLine("VoxelAssetChangedEvent");
System.Diagnostics.Debug.WriteLine($" AssetType: {args.AssetType}, ChangeType: {args.ChangeType}");
if (args.ChangeType == VoxelAssetEventArgs.VoxelAssetChangeType.Remove)
return;
//Get "what"changed - add or update
//eg IsoSurface
VoxelLayer voxelLayer = null;
if (args.AssetType == VoxelAssetEventArgs.VoxelAssetType.Isosurface)
var surface = MapView.Active.GetSelectedIsosurfaces().FirstOrDefault();
//there will only be one selected...
if (surface != null)
voxelLayer = surface.Layer;
//Repeat for Slices, Sections, LockedSections...
//GetSelectedSlices(), GetSelectedSections(), GetSelectedLockedSections();
