ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / AddPointZ Method
The point to add. The z-value of the point is used for the TIN.
The tag value for the new node. A value of 0 will result in no tag assignment.
Example
    AddPointZ Method
    Adds a 3D point as a node to the TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function AddPointZ( _
       ByVal point As MapPoint, _
       ByVal tagValue As Integer _
    ) As Integer
    public int AddPointZ(
       MapPoint point,
       int tagValue
    Parameters
    point
    tagValue
    Return Value
    The index of the newly added node. It will be one larger than the previous node count if the point is successfully added. It will be equal to the value of the existing node if it is snapped to it.
    Exceptions
    ExceptionDescription
    The point is null.
    The point is empty or point.HasZ is false.
    The editor is not in edit mode.
    Example
    Add z-aware point
      // Add a z-aware point with tag value = 56
      tinEditor.AddPointZ(pointZ, 56);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
