ArcGIS.Desktop.Mapping Namespace / MapTool Class / AddOverlayAsync Method / AddOverlayAsync(IEnumerable<CIMGraphic>,Double,Double) Method
The graphics to be added to the overlay.
Map reference scale or -1
Visibility factor for showing the overlay through other objects when obscured in 3D.
Valid range is [0..1], any other value will be treated as 0 (not visible).
    Add a set of overlay graphics to the map view.
    Syntax
    Protected Overloads Function AddOverlayAsync( _
       ByVal graphics As IEnumerable(Of CIMGraphic), _
       ByVal referenceScale As Double, _
       ByVal showThrough As Double _
    ) As Task(Of IDisposable)
    Parameters
    graphics
    referenceScale
    showThrough
    Return Value
    An object that when disposed will remove the overlay.
    Remarks
    When the tool is deactivated all overlay graphics will be removed.When the referenceScale is not equal to -1, the overlay will be created in real world units relative to the provided map reference scale (referenceScale). Otherwise, the overlay will be created in units of points. This is only supported in 2D.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
