ArcGIS.Desktop.Mapping Namespace / MapTool Class / UpdateOverlay Method / UpdateOverlay(IEnumerable<IDisposable>,IEnumerable<Geometry>,CIMSymbolReference,Double,Double) Method
The set of IDisposable instance returned from a group of AddOverlay method calls.
The set of geometry to be used for the update
The symbol to use for the update.
Map reference scale or -1
Visibility factor for showing the overlay through other objects when obscured in 3D.
Valid range is [0..1], any other value will be treated as 0 (not visible).
    Updates the geometry and symbol for a set of overlay graphics on the map view. Each overlay is drawn with the same symbol.
    Syntax
    Parameters
    overlays
    geometries
    symbol
    referenceScale
    showThrough
    Return Value
    True if the overlays were updated. False otherwise.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
