ArcGIS.Desktop.KnowledgeGraph Namespace / KnowledgeGraphInvestigationProjectItem Class / GetDatastore Method
Example
    GetDatastore Method (KnowledgeGraphInvestigationProjectItem)
    Gets the ArcGIS.Core.Data.Knowledge.KnowledgeGraph associated with the workspace corresponding to the ArcGIS.Desktop.Core.Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDatastore() As KnowledgeGraph
    public KnowledgeGraph GetDatastore()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get the KnowledgeGraph from a KnowledgeGraphInvestigationProjectItem
      // get an existing investigation
      var investigationProjectItems = Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>();
      var investigationProjectItem = investigationProjectItems.FirstOrDefault(ipi => ipi.Name.Equals("myInvestigation"));
      await QueuedTask.Run(() =>
        // get the datasore
        using (var kg = investigationProjectItem.GetDatastore())
          // do something
    Requirements
    ArcGIS Pro version: 3.5 or higher.
