ArcGIS.Desktop.Core Namespace / PresentationFrameworkExtender Class / CreatePresentationPaneAsync Method
Does not need to be specified.
Presentation
Example
    Creates and activates a new presentation pane using a Presentation reference. Must be called on GUI thread.
    Syntax
    Public Shared Function CreatePresentationPaneAsync( _
       ByVal paneCollection As PaneCollection, _
       ByVal presentation As Presentation _
    ) As Task(Of IPresentationPane)
    public static Task<IPresentationPane> CreatePresentationPaneAsync(
       PaneCollection paneCollection,
       Presentation presentation
    Parameters
    paneCollection
    presentation
    Presentation
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    Be sure to call this on the GUI thread. Do not execute within a QueuedTask.Run block.
    Example
    Reference an existing presentation
      //Reference a presentation associated with an active presentation view
      PresentationView associatedPresentationView = PresentationView.Active;
      if (activePresentationView != null)
        Presentation presentationExisting = activePresentationView.Presentation;
    Open a presentation project item in a new view
      //Open a presentation project item in a new view.
      //A presentation project item may exist but it may not be open in a view.
      //Reference a presentation project item by name
      PresentationProjectItem presentationPrjItem = Project.Current.GetItems<PresentationProjectItem>().FirstOrDefault(item => item.Name.Equals(presentationName));
      //Get the presentation associated with the presentation project item
      //Note: Must be within QueuedTask.Run
      Presentation presentationToOpen = presentationPrjItem.GetPresentation();
      //Create the new pane
      IPresentationPane iNewPresentationPane = await ProApp.Panes.CreatePresentationPaneAsync(presentationToOpen); //GUI thread
    Activate a presentation view
      //Assume we want to open a view for a particular presentation or activate a view if one is already open
      //A presentation project item is an item that appears in the Presentation folder in the Catalog pane.
      PresentationProjectItem presentationItem = Project.Current.GetItems<PresentationProjectItem>()
                                                 .FirstOrDefault(item => item.Name.Equals("Presentation Name"));
      //Note: Must be on QueuedTask.Run
      //Reference a presentation associated with a presentation project item
      if (presentationItem != null)
        //Get the presentation associated with the presentationItem
        Presentation presentationToOpen = presentationItem.GetPresentation();
        //Next check to see if a presentation view is already open that references the presentation
        foreach (var pane in ProApp.Panes)
          var prePane = pane as IPresentationPane;
          if (prePane == null)  // Not a presentation view, continue to the next pane
            continue;
          //if there is a match, activate the view
          if (prePane.PresentationView.Presentation == presentationToOpen)
            (prePane as Pane).Activate();
            return;
        //No pane found, activate a new one - must be called on UI
    Requirements
    ArcGIS Pro version: 3.5 or higher.
