Public Class Presentation Inherits ArcGIS.Desktop.Framework.Contracts.ViewModelBase Implements System.ComponentModel.INotifyPropertyChanged
public class Presentation : ArcGIS.Desktop.Framework.Contracts.ViewModelBase, System.ComponentModel.INotifyPropertyChanged
//Note: Call within QueuedTask.Run()
//Create mp4 format with appropriate settings
MP4VideoFormat mp4Format = new MP4VideoFormat();
mp4Format.Width = 800;
mp4Format.Height = 600;
mp4Format.OutputFileName = @"my folder\presentation.mp4";
//Define Export Options
PresentationExportOptions options = new PresentationExportOptions
PageRangeOption = ExportPageOptions.ExportByPageRange,
CustomPages = "1,2,8"
//export as mp4
presentation.Export(mp4Format, options);
//Note: Must be on QueuedTask
// add a new image page in current active presentation
var imagePage = presentation.AddImagePage("my image source", -1);
// change the image source
imagePage.SetImageSource("new image source");
// add a new video page in current active presentation
var videoPage = presentation.AddVideoPage("my video file", -1);
videoPage.SetVideoSource("new video source");
// change the start time of video to 3s
videoPage.SetStartTime(3.0);
// change the end time of video to 10s
videoPage.SetEndTime(10.0);
// retrieve a map from the project based on the map name
MapProjectItem mpi = Project.Current.GetItems<MapProjectItem>()
.FirstOrDefault(m => m.Name.Equals("Your Map Name", StringComparison.CurrentCultureIgnoreCase));
Map map = mpi.GetMap();
//create a map page using map's default extent
presentation.AddMapPage(map, -1);
//create a page using map's bookmark
Bookmark bookmark = map.GetBookmarks().FirstOrDefault(
b => b.Name == "Your bookmark"); // get the bookmark based on the bookmark's name
presentation.AddMapPage(bookmark, -1);
ArcGIS.Desktop.Presentations.Events.PresentationEvent.Subscribe((args) =>
var presentation = args.Presentation; //The presentation that was changed
//Check what triggered the event and take appropriate action
switch (args.Hint)
case PresentationEventHint.PropertyChanged:
//TODO handle presentation property changed
break;
case PresentationEventHint.PageAdded:
//TODO handle a new page added
break;
case PresentationEventHint.PageRemoved:
//TODO handle a page removed from the presentation
break;
case PresentationEventHint.PageSettingChanged:
//TODO handle page settings changed
break;
//For UI context changes associated with a presentation, subscribe to the PresentationView
//event - views activated/deactivated, views opened/closed
ArcGIS.Desktop.Presentations.Events.PresentationViewEvent.Subscribe((args) =>
//get the affected view and presentation
var view = args.PresentationView;
var presentation = args.PresentationView?.Presentation;
if (presentation == null)
//FYI presentationview and/or presentation can be null...
//eg closed, deactivation
switch (args.Hint)
case PresentationViewEventHint.Activated:
// Presentation view activated
break;
case PresentationViewEventHint.Opened:
//A PresentationView has been initialized and opened
break;
case PresentationViewEventHint.Deactivated:
// Presentation view deactivated
break;
case PresentationViewEventHint.Closing:
//Set args.Cancel = true to prevent closing
break;
case PresentationViewEventHint.ExtentChanged:
//presentation view extent has changed
break;
case PresentationViewEventHint.DrawingComplete:
break;
case PresentationViewEventHint.PauseDrawingChanged:
break;
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Presentations.Presentation
