ArcGIS.Desktop.Layouts Namespace / Layout Class / Print Method / Print() Method
    Print() Method
    Print a layout using default printer settings. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub Print()
    public void Print()
    Exceptions
    ExceptionDescription
    Remarks
    This method is intended to print a single page layout. Even if a map series is present, only the current layout page will be printed.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
