ArcGIS.Desktop.Presentations Namespace / MapPresentationPage Class / SetCamera Method / SetCamera(Layer) Method
Layer
Example
    Sets the map page extent using the layer's extent. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub SetCamera( _
       ByVal layer As Layer _
    public void SetCamera(
       Layer layer
    Parameters
    layer
    Layer
    Exceptions
    ExceptionDescription
    Example
    Change map page camera settings
      //Note: Must be on the QueuedTask
      //Reference a map page
      var mpage = activePresentationView.Presentation.GetPage(4) as MapPresentationPage;
      //Set the map frame extent based on the new camera's X,Y, Scale and heading values
      Camera cam = new Camera(329997.6648, 6248553.1457, 2403605.8968, 24);
      mpage.SetCamera(cam);
    Zoom map page to extent of a single layer
      //Reference map page
      //Reference map and layer
      MapProjectItem mp = Project.Current.FindItem("Page name") as MapProjectItem;
      Map map = mp.GetMap();
      FeatureLayer lyr = map.FindLayers("GreatLakes").First() as FeatureLayer;
      //Set the map frame extent to all features in the layer
      mpage.SetCamera(lyr);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
