ArcGIS.Desktop.Presentations Namespace / Presentation Class / GetCanEditMetadata Method
    GetCanEditMetadata Method (Presentation)
    Gets whether the presentation's metadata can be edited or not. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetCanEditMetadata() As Boolean
    public bool GetCanEditMetadata()
    Return Value
    True if the metadata is editable
    Exceptions
    ExceptionDescription
    Remarks
    The metadata is typically editable unless the .aprx is not editable
    Requirements
    ArcGIS Pro version: 3.5 or higher.
