ArcGIS.Desktop.Presentations Namespace / Presentation Class / SetAspectRatio Method
The horizontal component of the aspect ratio
The vertical component of the aspect ratio
    Changes the aspect ratio of the presentation. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetAspectRatio( _
       ByVal width As Integer, _
       ByVal height As Integer _
    public void SetAspectRatio(
       int width,
       int height
    Parameters
    width
    height
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    For example, SetAspectRatio(16, 9) changes the aspect ratio to 16:9.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
