ArcGIS.Desktop.Presentations Namespace / PresentationView Class / PageToClient Method
The point in page coordinates
    PageToClient Method (PresentationView)
    Converts a point in page coordinates to a point in client coordinates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function PageToClient( _
       ByVal pageCoord As Coordinate2D _
    ) As Point
    public Point PageToClient(
       Coordinate2D pageCoord
    Parameters
    pageCoord
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    Page coordinates must be in the current units of the page. Client coordinates will be in pixels relative to the top-left corner of the view. If either page coordinate value is double.NaN then a point with X, Y both set to System.Double.NaN is returned.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
