ArcGIS.Desktop.Presentations Namespace / PresentationView Class / PageToScreen Method
The point on the page.
    PageToScreen Method (PresentationView)
    Converts a point in page coordinates to screen coordinates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function PageToScreen( _
       ByVal pageCoord As Coordinate2D _
    ) As Point
    public Point PageToScreen(
       Coordinate2D pageCoord
    Parameters
    pageCoord
    Return Value
    The converted point in screen coordinates
    Exceptions
    ExceptionDescription
    Remarks
    Page coordinates must be in the current units of the page. If either page coordinate value is double.NaN then a point with X, Y both set to System.Double.NaN is returned.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
