ArcGIS.Desktop.Mapping Namespace / DefinitionQuery Class / SetFilterGeometry Method
The geometry to be set as the filter
Example
    Set the definition query filter geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetFilterGeometry( _
       ByVal filterGeometry As Geometry _
    public void SetFilterGeometry(
       Geometry filterGeometry
    Parameters
    filterGeometry
    Exceptions
    ExceptionDescription
    Invalid filter geometry
    Remarks
    Specifying an invalid geometry as the filter geometry will throw a System.ArgumentException. Refer to CanSetFilterGeometry. The filter geometry will be converted to a Uri and assigned to GeometryUri. SpatialReference will be set to the spatial reference of the filter geometry
    Example
    Querying a feature layer with a spatial filter
        var layers = map.GetLayersAsFlattenedList().OfType<FeatureLayer>();
        var layerToQuery = layers.FirstOrDefault(f => f.Name == "USNationalParks");
        if (layerToQuery == null) return;
        string whereClause = "RecreationVisitsTotal > 1000000"; //More than million visitors a year
        var spatialDefnLayer = layers.FirstOrDefault(f => f.Name == "AllUSStates");
        if (spatialDefnLayer == null) return;
        try
            if (MapView.Active == null) return;
            //Note: needs to be called on the MCT
            // Set the spatial filter geometry
            //Get the geometry from the selected features in the feature layer
            var spatialClauseGeom = spatialDefnLayer.GetFeatureOutline(MapView.Active, FeatureOutlineType.Selected);
            //Create the definition query
            DefinitionQuery definitionQuery = new DefinitionQuery
                WhereClause = whereClause,
                Name = $"{layerToQuery.Name}"
            //Setting the spatial filter to the Definition Query
            if (definitionQuery.CanSetFilterGeometry(spatialClauseGeom))
                definitionQuery.SetFilterGeometry(spatialClauseGeom);
            layerToQuery.InsertDefinitionQuery(definitionQuery);
            layerToQuery.SetActiveDefinitionQuery(definitionQuery.Name);
        catch (Exception ex)
            System.Diagnostics.Debug.WriteLine($"Error querying feature layer: {ex.Message}");
    Apply A Definition Query Filter With a Filter Geometry to a Feature Layer
        var greatLakes = map.GetLayersAsFlattenedList()
              .OfType<FeatureLayer>().First(l => l.Name == "Great Lakes");
        var usa_states = map.GetLayersAsFlattenedList()
        .OfType<FeatureLayer>().First(l => l.Name == "US_States");
        //name must be unique
        var def_query = new DefinitionQuery("GreatLakes",
                              "NAME in ('Huron','Michigan','Erie')");
        //create a filter geometry - in this example we will use the outline geometry
        //of all visible features from a us states layer...the filter geometry will be
        //intersected with the layer feature geometry when added to the def query
        var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Visible);
        //other options...
        //var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.All);
        //var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Selected);
        //Geometry must have a valid SR and be point, multi-point, line, or poly
        if (def_query.CanSetFilterGeometry(filter_geom))
            def_query.SetFilterGeometry(filter_geom);
        //Apply the def query
        greatLakes.InsertDefinitionQuery(def_query);
        //Set it active
        greatLakes.SetActiveDefinitionQuery(def_query.Name);
        //or....also - set it active when it is inserted
        //greatLakes.InsertDefinitionQuery(def_query, true);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
