ArcGIS.Desktop.Mapping Namespace / ElevationProfileParameters Class / SurfaceLayer Property
Example
    Gets and sets the elevation surface layer used to obtain the elevation values. Default value is null. If null is specified, then the default Ground Surface will be used.
    Syntax
    Public Property SurfaceLayer As ElevationSurfaceLayer
    public ElevationSurfaceLayer SurfaceLayer {get; set;}
    Example
    Show Elevation profile graph with a specific surface
        if (!MapView.Active.CanShowElevationProfileGraph())
            return;
        // use a specific elevation surface
        var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
        // set up the parameters
        var profileParams = new ElevationProfileParameters();
        profileParams.SurfaceLayer = eleLayer;
        profileParams.Densify = true;
        // show the elevation profile for a polyline using the params
        //Any line
        Polyline polyline = PolylineBuilderEx.CreatePolyline();
        MapView.Active.ShowElevationProfileGraph([polyline], profileParams);
        // show the elevation profile for a set of points using the params
        //Some points
        MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
        List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
        MapView.Active.ShowElevationProfileGraph(mapPoints, profileParams);
    Show Elevation profile graph between two points
        int numPoints = 20;
            return;
        // use the default ground elevation surface
        MapPoint startPt = MapPointBuilderEx.CreateMapPoint(-130, 20, SpatialReferences.WGS84);
        MapPoint endPt = MapPointBuilderEx.CreateMapPoint(-100, 50, SpatialReferences.WGS84);
        MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints);
        // find a specific elevation surface layer
        var tinLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
        // set up the params
        var elevProfileParams = new ElevationProfileParameters();
        elevProfileParams.SurfaceLayer = tinLayer;
        elevProfileParams.Densify = false;
        // show the elevation profile using the params
        MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints, elevProfileParams);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
