ArcGIS.Desktop.Mapping Namespace / MapView Class / Print Method / Print(PrinterSettingsInfo) Method
PrinterSettingsInfo
    Print a mapview using the specified settings. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub Print( _
       ByVal printerSettingsInfo As PrinterSettingsInfo _
    Parameters
    printerSettingsInfo
    PrinterSettingsInfo
    Exceptions
    ExceptionDescription
    Printing is disabled or not possible due to stream layers.
    Remarks
    Check CanPrint before printing
    Requirements
    ArcGIS Pro version: 3.5 or higher.
