ArcGIS.Desktop.Core Namespace / ICatalogWindow Interface / GetCurrentContentType Method
Example
    Gets the current catalog content type being shown in the catalog dock pane
    Syntax
    Function GetCurrentContentType() As CatalogContentType
    CatalogContentType GetCurrentContentType()
    Example
    Get the catalog content type currently being shown
      //Gets the Catalog pane
      var catalogWindow = Project.GetCatalogPane() as ICatalogWindow;
      var catContentType = catalogWindow.GetCurrentContentType();
      // use catContentType;
    Set the catalog content type
      if (!catalogWindow.IsActiveWindow)
        //catalog dockpane must be the active window
      //Change the content to whatever is the next tab
      var catContentType = (int)catalogWindow.GetCurrentContentType();
      catContentType++;
      if (catContentType > (int)CatalogContentType.Favorites)
        catContentType = (int)CatalogContentType.Project;
      //Must be on the UI - no QueuedTask!
      catalogWindow.SetContentTypeAsync((CatalogContentType)catContentType);
    Set the secondary portal catalog content
      //Is portal content being shown?
      if (catContentType == CatalogContentType.Portal)
        //check what is the portal content type being shown...
        var portalContentType = (int)catalogWindow.GetCurrentSecondaryPortalContentType();
        //advance to the next tab
        portalContentType++;
        if (portalContentType > (int)CatalogSecondaryPortalContentType.LivingAtlas)
          portalContentType = (int)CatalogSecondaryPortalContentType.UserContent;
        //set the secondary portal content type
        catalogWindow.SetSecondaryPortalContentTypeAsync(
          (CatalogSecondaryPortalContentType)portalContentType);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
