SetSecondaryPortalContentTypeAsync Method
Sets the catalog secondary portal content type to be shown in the catalog dock pane. This method must be called on the UI thread.
Set the secondary portal catalog content
//Gets the Catalog pane
var catalogWindow = Project.GetCatalogPane() as ICatalogWindow;
if (!catalogWindow.IsActiveWindow)
//catalog dockpane must be the active window
var catContentType = catalogWindow.GetCurrentContentType();
//Is portal content being shown?
if (catContentType == CatalogContentType.Portal)
//check what is the portal content type being shown...
var portalContentType = (int)catalogWindow.GetCurrentSecondaryPortalContentType();
//advance to the next tab
portalContentType++;
if (portalContentType > (int)CatalogSecondaryPortalContentType.LivingAtlas)
portalContentType = (int)CatalogSecondaryPortalContentType.UserContent;
//set the secondary portal content type
//Must be on the UI - no QueuedTask!
catalogWindow.SetSecondaryPortalContentTypeAsync(
(CatalogSecondaryPortalContentType)portalContentType);
ArcGIS Pro version: 3.6 or higher.
