ArcGIS.Desktop.Mapping Namespace / DiagramLayer Class / MoveLayer Method
A Layer to be moved.
The position specified by the 0-based index. -1 will move the table to the bottom of the container. If the index is invalid, the layer is moved to the bottom.
    MoveLayer Method (DiagramLayer)
    Move a layer to another position within the container. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void MoveLayer(
       Layer layer,
       int position
    Public Sub MoveLayer( _
       ByVal layer As Layer, _
       ByVal position As Integer _
    Parameters
    layer
    position
    Exceptions
    ExceptionDescription
    The layer is null.
    Invalid container. The layer is not part of this diagram layer.
    Remarks
    The layer must already be part of this diagram layer.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
