ArcGIS.Desktop.Mapping Namespace / SelectionSet Class / Equals Method / Equals(SelectionSet) Method
The SelectionSet used in the comparison.
Example
    Determines whether the specified SelectionSet is equivalent to the current SelectionSet.
    Syntax
    Public Overloads Function Equals( _
       ByVal other As SelectionSet _
    ) As Boolean
    public bool Equals(
       SelectionSet other
    Parameters
    other
    Return Value
    True if the SelectionSet is equivalent.
    Example
    Check SelectionSet Equality
        // get map selection
        var mapSelSet = MapView.Active.Map.GetSelection();
        // create a selectionSet
        var selDict = new Dictionary<MapMember, List<long>>();
        selDict.Add(featureLayer, new List<long> { 1506, 2696, 2246, 1647, 948 });
        var layerSelSet = ArcGIS.Desktop.Mapping.SelectionSet.FromDictionary(selDict);
        // test for equality - use Equals method
        var isEquals = mapSelSet.Equals(layerSelSet);
        // test for equality - use operators
        var equals = mapSelSet == layerSelSet;
        var notEquals = mapSelSet != layerSelSet;
    Requirements
    ArcGIS Pro version: 3.6 or higher.
