ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphIDSet Class / Contains Method
The named object type to check.
    Contains Method (KnowledgeGraphIDSet)
    Determines if the specified named object type is in the ID set.
    Syntax
    Public Function Contains( _
       ByVal namedObjectType As String _
    ) As Boolean
    public bool Contains(
       string namedObjectType
    Parameters
    namedObjectType
    Return Value
    True if the ID set contains the named object type.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
