ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphIDSet Class
Properties Methods
    KnowledgeGraphIDSet Class Members
    The following tables list the members exposed by KnowledgeGraphIDSet.
    Public Properties
     NameDescription
    Public Property Gets if the ID set is empty.
    Public Property Gets the count of named object types in the ID set.
    Top
    Public Methods
     NameDescription
    Public Method Determines if the specified named object type is in the ID set.
    Public Methodstatic (Shared in Visual Basic)Overloaded.
    Public Method Gets the list of entity and relationship types names in the ID set. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the set of invalid named types in the set. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Creates the dictionary of named object types and their corresponding objectIDs.
    Public Method Creates the dictionary of named object types and their corresponding IDs. This method must be called on the MCT. Use QueuedTask.Run.
    Top
