ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphIDSet Class / GetEntityRelationshipTypeNames Method
    GetEntityRelationshipTypeNames Method (KnowledgeGraphIDSet)
    Gets the list of entity and relationship types names in the ID set. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Return Value
    The lists of entity and relationship types names in the ID set as a tuple.
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.6 or higher.
