ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphIDSet Class / FromKnowledgeGraph Method / FromKnowledgeGraph(Uri,KnowledgeGraphFilterMethod) Method
A Uri link to a knowledge graph service or file-based knowledge graph
The set of named type objects to include in the filter.
    Creates a KnowledgeGraphIDSet with a particular filter. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    knowledgeGraphPathOrServiceUri
    filterMethod
    Return Value
    Exceptions
    ExceptionDescription
    The knowledgeGraphServiceUri is null.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
