ArcGIS.Desktop.Reports Namespace / ReportFactory Class / CreateReport Method / CreateReport(String,ReportCustomTemplateDefinition) Method
The name of the report.
T:ArcGIS.Desktop.Reports.ReportCustomTemplateDefinition object defining data sources, fields, maps, charts and supplemental pages to populate template.
Example
    Creates a new report using a custom template and adds it to a project. The source data for the report can be either a Layer or Table or a data connection to the data. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateReport( _
       ByVal name As String, _
       ByVal templateDataDef As ReportCustomTemplateDefinition _
    ) As Report
    Parameters
    name
    templateDataDef
    Return Value
    The created report.
    Exceptions
    ExceptionDescription
    Template data is invalid.
    Example
    Create report
      //Note: Call within QueuedTask.Run()
      //The fields in the datasource used for the report
      //This uses a US Cities dataset
      var listFields = new List<CIMReportField> {
              //Grouping should be the first field
              new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
              new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
              new CIMReportField{Name = "POP1990", FieldOrder = 2, },
      //Definition query to use for the data source
      var defQuery = "STATE_NAME LIKE 'C%'";
      //Define the Datasource
      var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
      //The CIMPage defintion - page size, units, etc
      var cimReportPage = new CIMPage
        Height = 11,
        StretchElements = false,
        Width = 6.5,
        ShowRulers = true,
        ShowGuides = true,
        Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
        Units = LinearUnit.Inches
      //Report template
      var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
      var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
      //Report Styling
      var reportStyles = await ReportStylingManager.GetStylingsAsync();
      var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
      //Field Statistics
      var fieldStatisticsList = new List<ReportFieldStatistic> {
              new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
              //Note: NoStatistics option for FieldStatisticsFlag is not supported.
      var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
    Create a report from a custom report template
      //Note: Run within QueuedTask.Run()
      // get the first map in the project
      MapProjectItem item = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(n => n.Name == "Cities");
      if (item == null)
        return;
      Map map = item.GetMap();
      if (map == null)
        return;
      Layer cityLayer = map.FindLayers("U.S. Cities")[0];
      if (cityLayer == null)
        return;
      // load template information
      var templatePath = System.IO.Path.Combine($@"{Project.Current.HomeFolderPath}\TemplateSimpleReportWithTokens.rptt");
      ReportCustomTemplateDefinition templateDef = ReportTemplateManager.GetCustomTemplateDefinition(templatePath);
      if (templateDef == null || templateDef.ReportTemplateDataSourceItems?.Count() < 1)
        return;
      // get template info of first data source (parent) and set its data source
      ReportCustomTemplateDataSourceInfo parentDataSourceInfo = templateDef.ReportTemplateDataSourceItems.ElementAt(0);
      parentDataSourceInfo.SetReportDataSource(cityLayer);
      TemplateTokenFieldInfoValues templateTokenFieldInfoValues = parentDataSourceInfo.TokenInfoValues;
      parentDataSourceInfo.DefinitionQuery = "STATE_NAME = 'Massachusetts'";
      templateTokenFieldInfoValues["[text-field-value-0]"] = "CITY_NAME";
      templateTokenFieldInfoValues["[text-field-name-0]"] = "City";
      templateTokenFieldInfoValues["[numeric-field-value-0]"] = "POP1990";
      templateTokenFieldInfoValues["[numeric-field-name-0]"] = "Population";
      if (templateDef.CanCreateReport())
        // create the report
        report = ReportFactory.Instance.CreateReport("RelateSiblingsFromCode", templateDef);
      //UI thread
      if (report != null)
        //open report
        await FrameworkApplication.Panes.CreateReportPaneAsync(report);
    Requirements
    ArcGIS Pro version: 3.6 or higher.
