Public Class KnowledgeGraphFilteredFindPathsResults
public class KnowledgeGraphFilteredFindPathsResults
//using ArcGIS.Core.Data.Knowledge.Extensions;
await QueuedTask.Run(() =>
var ffp_config = new CIMFilteredFindPathsConfiguration();
ffp_config.Name = "Run FFP Using Defaults";
//Origin Entities
var originEntities = new List<CIMFilteredFindPathsEntity>();
var poi_entity = new CIMFilteredFindPathsEntity();
poi_entity.EntityTypeName = "POI";//All entities of entity type "POI"
poi_entity.PropertyFilterPredicate = "";
originEntities.Add(poi_entity);
//Add the CIMFilteredFindPathsEntity to the OriginEntities collection
ffp_config.OriginEntities = originEntities.ToArray();
//Destination Entities
var destEntities = new List<CIMFilteredFindPathsEntity>();
var supp_entity = new CIMFilteredFindPathsEntity();
supp_entity.EntityTypeName = "Supplier";//All entities of entity type "Supplier"
supp_entity.PropertyFilterPredicate = "";
destEntities.Add(supp_entity);
//Add the CIMFilteredFindPathsEntity to the DestinationEntities collection
ffp_config.DestinationEntities = destEntities.ToArray();
//Path Filters
ffp_config.PathFilters = [];//Empty
//Traversal
ffp_config.TraversalDirections = [];//Empty
//Other
ffp_config.RelationshipCostProperty = "";
ffp_config.DefaultRelationshipCost = 1.0;
ffp_config.DefaultTraversalDirectionType = KGTraversalDirectionType.Any;
ffp_config.EntityUsage = FilteredFindPathsEntityUsage.AnyOriginAnyDestination;
ffp_config.PathMode = KGPathMode.Shortest;
ffp_config.MinPathLength = (int)1;//Min number of relationships in path
ffp_config.MaxPathLength = (int)8;//Max number of relationships in path
ffp_config.MaxCountPaths = (int)100000;//Total number of paths to return
ffp_config.ClosedPathPolicy = KGClosedPathPolicy.Forbid;
ffp_config.TimeFilter = null;
var results = kg.RunFilteredFindPaths(ffp_config);
//TODO process/analyze results
await QueuedTask.Run(async () =>
ffp_config.Name = "Create Link Chart from FFP Results";
//set up config
var pathsEntitiesAndRelationships = results.ExtractPathsEntitiesAndRelationships(null);
//Create a KG layer id set
var kgLayerIdSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
pathsEntitiesAndRelationships.ToKnowledgeGraphIDSet(
KGResultContentFromFFP.EntitiesAndRelationships));
//Create a brand new link chart with the results and show it
var linkChart = MapFactory.Instance.CreateLinkChart("KG Intro", kg, kgLayerIdSet);
var mapPane = await FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
var linkChartView = mapPane.MapView;
//Change layout algo to match the default used by the UI after FFP
await linkChartView.SetLinkChartLayoutAsync(
KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom);
//Set root nodes - they correspond to the origin nodes of the result paths
var kgLayerIdSetForRootNodes = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
KGResultContentFromFFP.OnlyPathsOriginEntities));
//To correctly identify the ids in the link chart we must change the ids
//from Geodatabase oids returned in the KnowledgeGraphLayerIDSet to the
//temporary/synthetic oids used by layers in the link chart...
var kg_layer = linkChart.GetLayersAsFlattenedList().OfType<KnowledgeGraphLayer>().First();
var mapMembers = kg_layer.GetMapMembersAsFlattenedList();
var oidDict = kgLayerIdSetForRootNodes.ToOIDDictionary();
var mmDict = new Dictionary<MapMember, List<long>>();
foreach (var kvp in oidDict)
var named_type = kvp.Key;
foreach (var mm in mapMembers)
if (mm is LinkChartFeatureLayer fl_lc && fl_lc.IsEntity)
if (fl_lc.GetTypeName().ToLower() == named_type.ToLower())
var lc_oids = new List<long>();
//these oids are from the geodatabase
var oid_field = $"{fl_lc.GetTypeName()}.objectid";
var id_list = string.Join(',', kvp.Value.ToArray());
var where = $"{fl_lc.GetTypeName()}.objectid IN ({id_list})";
var qf = new ArcGIS.Core.Data.QueryFilter()
WhereClause = where,
SubFields = $"LC.OID,{oid_field}"//the 'LC.OID' oids are the ones
//we need for the mapmember id set
//in the link chart
var rc = fl_lc.Search(qf);
var oid_idx = rc.FindField(oid_field);
while (rc.MoveNext())
var oid = (long)rc.Current[oid_idx];
var lc_oid = rc.Current.GetObjectID();
lc_oids.Add(lc_oid);
rc.Dispose();
mmDict[fl_lc] = lc_oids;
break;
var mmIdSet = MapMemberIDSet.FromDictionary(mmDict);
linkChartView.SetRootNodes(mmIdSet);
var linkChartView = MapView.Active;
ffp_config.Name = "Append to Link Chart from FFP Results";
//set up config
var map = linkChartView.Map;
if (!map.CanAppendToLinkChart(kgLayerIdSet))
return;//not compatible
map.AppendToLinkChart(kgLayerIdSet);
//switch layout algo
var algo = linkChartView.GetLinkChartLayout();
if (algo != KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom)
//To set link chart root nodes see 'Create Link Chart from FFP Results'
ffp_config.Name = "List out FFP Results by Path Length, Min Cost, Max Cost";
//set up config
if (results.CountPaths == 0)
System.Diagnostics.Debug.WriteLine("FFP returned no paths");
return;
//print out paths by increasing length, min cost, max cost
var path_by_len_indices = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingPathLength
.Select(idx => idx.index);
var path_by_min_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMinPathCost
var path_by_max_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMaxPathCost
var x = 0;
StringBuilder sb = new StringBuilder();
foreach (var path_indeces in new List<IEnumerable<long>> {
path_by_len_indices,
path_by_min_cost,
path_by_max_cost})
if (x == 0)
sb.AppendLine($"Paths by length: {path_by_len_indices.Count()}");
else if (x == 1)
sb.AppendLine($"Paths by min cost: {path_by_min_cost.Count()}");
else if (x == 2)
sb.AppendLine($"Paths by max cost: {path_by_max_cost.Count()}");
x++;
foreach (var path_idx in path_indeces)
var path = (ResultPath)results.MaterializePath(path_idx);
sb.AppendLine(
$"Path[{path_idx}] length: {path.Length}, min: {path.MinCost} max: {path.MaxCost}");
var g = 0;
foreach (var rel_group in path.RelationshipGroups)
var first_entity = $"({rel_group.FirstEntity.TypeName}:{rel_group.FirstEntity.Uid})";
var second_entity = $"({rel_group.SecondEntity.TypeName}:{rel_group.SecondEntity.Uid})";
foreach (var relation in rel_group.Relationships)
sb.Append($" [{g++}] ");
var arrow = relation.SameDirectionAsPath ? "->" : "<-";
var rel_uid = FormatUID(relation.Relationship.Uid.ToString());
sb.Append($"{first_entity} '\r\n\t{relation.Relationship.TypeName}:{rel_uid}' {arrow}\r\n" +
$"\t\t{second_entity}");
sb.Append($" cost: {relation.Relationship.Cost}\r\n");
string FormatUID(string id)
id = id.ToUpperInvariant();
if (!id.StartsWith('{'))
id = '{' + id;
if (!id.EndsWith('}'))
id += '}';
return id;
ffp_config.Name = "List out FFP Results Origin, Destination, Other Entities";
//set up config
return;
var x = 0;
path_by_min_cost,
path_by_max_cost})
if (x == 0)
sb.AppendLine($"Entities by length: {path_by_len_indices.Count()}");
else if (x == 1)
sb.AppendLine($"Entities by min cost: {path_by_min_cost.Count()}");
else if (x == 2)
sb.AppendLine($"Entities by max cost: {path_by_max_cost.Count()}");
x++;
sb.AppendLine(
var sorted_set = new SortedSet<ulong>();
sorted_set.Add((ulong)path_idx);
var per = results.ExtractPathsEntitiesAndRelationships(sorted_set);
var origin_dest_uids = new List<string>();
var sep = "";
sb.Append(" Origin EntitiesUIDs: ");
foreach (var idx in per.PathsOriginEntitiesUIDsIndexes)
//See 'List out FFP Results by Path Length, Min Cost, Max Cost' for
//FormatID method above
var uid = FormatID(per.EntitiesUIDs[idx].ToString());
origin_dest_uids.Add(uid);
var origin =
$"{sep}{per.EntityTypeNames[per.EntityTypes[idx]]}:{uid}";
sep = ", ";
sb.Append($"{origin}");
sb.AppendLine("");
sep = "";
sb.Append(" Destination EntitiesUIDs: ");
foreach (var idx in per.PathsDestinationEntitiesUIDsIndexes)
var dest =
sep = ", ";
sb.Append($"{dest}");
sb.AppendLine("");
sep = "";
var idx2 = 0;
sb.Append(" Other EntitiesUIDs: ");
bool wereAnyOthers = false;
foreach (var raw_uid in per.EntitiesUIDs)
var uid = FormatID(raw_uid.ToString());
if (!origin_dest_uids.Contains(uid))
var other =
$"{sep}{per.EntityTypeNames[per.EntityTypes[idx2]]}:{uid}";
sep = ", ";
sb.Append($"{other}");
wereAnyOthers = true;
idx2++;
if (!wereAnyOthers)
sb.Append(" <<none>>");
//sb.AppendLine("");
var entity_str = sb.ToString();
System.Diagnostics.Debug.WriteLine(entity_str);
sb.Clear();
sep = "";
ffp_config.Name = "List out FFP Results Relationships";
//set up config
return;
var x = 0;
path_by_min_cost,
path_by_max_cost})
if (x == 0)
sb.AppendLine($"Relationships by length: {path_by_len_indices.Count()}");
else if (x == 1)
sb.AppendLine($"Relationships by min cost: {path_by_min_cost.Count()}");
else if (x == 2)
sb.AppendLine($"Relationships by max cost: {path_by_max_cost.Count()}");
x++;
sb.AppendLine(
var idx = 0;
foreach (var rel_uid in per.RelationshipsUIDs)
sb.Append($" RelationshipsUIDs[{idx}]: ");
var uid = FormatID(rel_uid.ToString());
var rel_info =
$"{per.RelationshipTypeNames[per.RelationshipTypes[idx]]}:{uid}";
sb.Append($"{rel_info}\r\n");
//From entity:
var entity_idx = per.RelationshipsFrom[idx];
var origin_uid = FormatID(per.EntitiesUIDs[entity_idx].ToString());
var origin = $"{per.EntityTypeNames[per.EntityTypes[entity_idx]]}:{origin_uid}";
sb.Append($" RelationshipsFrom: {origin}\r\n");
//To entity
entity_idx = per.RelationshipsTo[idx];
var dest_uid = FormatID(per.EntitiesUIDs[entity_idx].ToString());
var dest = $"{per.EntityTypeNames[per.EntityTypes[entity_idx]]}:{dest_uid}";
sb.Append($" RelationshipsTo: {dest}\r\n");
idx++;
var rel_str = sb.ToString();
System.Diagnostics.Debug.WriteLine(rel_str);
sb.Clear();
string FormatID(string id)
id = '{' + id;
id += '}';
return id;
System.Object
ArcGIS.Core.Data.Knowledge.Analytics.KnowledgeGraphFilteredFindPathsResults
