ArcGIS.Core.Data.Knowledge.Analytics Namespace / KnowledgeGraphFilteredFindPathsResults Class / PathIndicesOrderedByIncreasingMinPathCost Property
Example
    Returns an array of (min path cost, path index) ordered by increasing "min path cost".
    Syntax
    Public ReadOnly Property PathIndicesOrderedByIncreasingMinPathCost As ValueTuple(Of Double,Long)()
    public ValueTuple<double,long>[] PathIndicesOrderedByIncreasingMinPathCost {get;}
    Remarks
    The paths indexes present in this array are guaranteed to correspond to valid paths, i.e a subsequent call to MaterializePath using any of these indexes will return a non-null value.
    Example
    List out FFP Results by Path Length, Min Cost, Max Cost
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(async () =>
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "List out FFP Results by Path Length, Min Cost, Max Cost";
        //set up config
        var results = kg.RunFilteredFindPaths(ffp_config);
        if (results.CountPaths == 0)
          System.Diagnostics.Debug.WriteLine("FFP returned no paths");
          return;
        //print out paths by increasing length, min cost, max cost
        var path_by_len_indices = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingPathLength
                                    .Select(idx => idx.index);
        var path_by_min_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMinPathCost
        var path_by_max_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMaxPathCost
        var x = 0;
        StringBuilder sb = new StringBuilder();
        foreach (var path_indeces in new List<IEnumerable<long>> {
        path_by_len_indices,
        path_by_min_cost,
        path_by_max_cost})
          if (x == 0)
            sb.AppendLine($"Paths by length: {path_by_len_indices.Count()}");
          else if (x == 1)
            sb.AppendLine($"Paths by min cost: {path_by_min_cost.Count()}");
          else if (x == 2)
            sb.AppendLine($"Paths by max cost: {path_by_max_cost.Count()}");
          x++;
          foreach (var path_idx in path_indeces)
            var path = (ResultPath)results.MaterializePath(path_idx);
            sb.AppendLine(
              $"Path[{path_idx}] length: {path.Length}, min: {path.MinCost} max: {path.MaxCost}");
            var g = 0;
            foreach (var rel_group in path.RelationshipGroups)
              var first_entity = $"({rel_group.FirstEntity.TypeName}:{rel_group.FirstEntity.Uid})";
              var second_entity = $"({rel_group.SecondEntity.TypeName}:{rel_group.SecondEntity.Uid})";
              foreach (var relation in rel_group.Relationships)
                sb.Append($"  [{g++}] ");
                var arrow = relation.SameDirectionAsPath ? "->" : "<-";
                var rel_uid = FormatUID(relation.Relationship.Uid.ToString());
                sb.Append($"{first_entity} '\r\n\t{relation.Relationship.TypeName}:{rel_uid}' {arrow}\r\n" +
                  $"\t\t{second_entity}");
                sb.Append($" cost: {relation.Relationship.Cost}\r\n");
    string FormatUID(string id)
      id = id.ToUpperInvariant();
      if (!id.StartsWith('{'))
        id = '{' + id;
      if (!id.EndsWith('}'))
        id += '}';
      return id;
    Requirements
    ArcGIS Pro version: 3.6 or higher.
