ArcGIS.Desktop.Mapping Namespace / RasterLayer Class / SetDisplayField Method
The Display Field name.
    SetDisplayField Method (RasterLayer)
    Sets the name of the attribute field that will be used to identify features or rows. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetDisplayField( _
       ByVal displayField As String _
    public void SetDisplayField(
       string displayField
    Parameters
    displayField
    Exceptions
    ExceptionDescription
    Remarks
    The display field is also used in map tips, popups, editing tools and selection chip. The display field must be able to be represented as a string.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
