ArcGIS.Core.CIM Namespace / CIMFormAttachmentElement Class
    CIMFormAttachmentElement Class Properties
    For a list of all members of this type, see CIMFormAttachmentElement members.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the user renaming an attachment is allowed.
    Public Property Gets or sets the input user interface to use for the attachment.
    Public Property Gets or sets a string to identify the attachment(s). When a file is attached using the form, this property is used to set the value of the keywords field for the attachment. When a form is displaying existing attachments, this property is used to query attachments using an exact match on the keywords field.
    Public Property Gets or sets a string that describes the element in detail.
    Public Property Gets or sets a value indicating whether the file name should be displayed. Default is 'false'.
    Public Property Gets or sets the name of an Arcade expression that returns a boolean value. When this expression evaluates to 'true', the element is editable. When the expression evaluates to 'false' the element is not editable.
    Public Property Gets or sets an Arcade expression that is evaluated to produce filenames for new attachments. If not specified, a unique name will be generated using the 'AttachmentKeyword' and the current timestamp when the attachment is added.
    Public Property Gets or sets a string value indicating what the element represents.
    Public Property Gets or sets the maximum number of attachments allowed for this element. If set (or defaulted) to -1, there is no maximum.
    Public Property Gets or sets the minimum number of attachments required for this element. If set (or defaulted) to 0, no attachements are required.
    Public Property Gets or sets a value indicating whether the uploaded attachment's file name is preserved. If 'false', the name is updated based on 'FilenameExpression'. Default is 'true'.
    Public Property Gets or sets the name of an Arcade expression that returns a boolean value. When this expression evaluates to 'true', the element is displayed. When the expression evaluates to 'false' the element is not displayed. If no expression is provided, the default behavior is that the element is displayed.
    Top
