RequiredExpressionName Property
Gets or sets the name of an Arcade expression that returns a boolean value. When this expression
evaluates to 'true' and the element is visible, the element must have a valid value in order for
the feature to be created or edited. When the expression evaluates to 'false' the element is not
required. If no expression is provided, the default behavior is that the element is not required.
If the referenced field is non-nullable, the required expression is ignored and the element is
always required.
ArcGIS Pro version: 3.7 or higher.
