ArcGIS.Core.CIM Namespace / CIMFormUtilityNetworkAssociationsElement Class / EditableExpressionName Property
    EditableExpressionName Property (CIMFormUtilityNetworkAssociationsElement)
    Gets or sets the name of an Arcade expression that returns a boolean value. When this expression evaluates to 'true', the element is editable. When the expression evaluates to 'false' the element is not editable. If the referenced related table is not editable, the editable expression is ignored and the element is not editable.
    Syntax
    public string EditableExpressionName {get; set;}
    Public Property EditableExpressionName As String
    Remarks
    If set, this name must match the Name of exactly one expression in the form's ExpressionInfos array.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
