ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / CircuitExportOptions Class / TraceConfiguration Property
Example
    TraceConfiguration Property (CircuitExportOptions)
    Gets or sets the trace configuration for the export.
    Syntax
    public TraceConfiguration TraceConfiguration {get; set;}
    Public Property TraceConfiguration As TraceConfiguration
    Example
    Export circuits
    await QueuedTask.Run(() =>
      using (TraceManager traceManager = utilityNetwork.GetTraceManager())
      using (CircuitManager circuitManager = utilityNetwork.GetCircuitManager(telecomDomainNetwork))
      using (UtilityNetworkDefinition utilityNetworkDefinition = utilityNetwork.GetDefinition())
        IReadOnlyList<NetworkSource> networkSources = utilityNetworkDefinition.GetNetworkSources();
        IReadOnlyList<NetworkAttribute> networkAttributes = utilityNetworkDefinition.GetNetworkAttributes();
        IEnumerable<string> networkAttributeNames = networkAttributes.Select(s => s.Name);
        NetworkSource telcoDeviceNWSource = networkSources.First(f => f.Name.Contains("TelcoDevice"));
        NetworkSource telcoCircuit = networkSources.First(f => f.Name.Contains("TelcoCircuit"));
        TraceConfiguration traceConfiguration = new TraceConfiguration()
          InferConnectivity = false,
          DomainNetwork = telecomDomainNetwork,
          IncludeContainers = true,
          IncludeContent = true,
          SynthesizeGeometries = false
        ResultOptions resultOptions = new ResultOptions()
          IncludeGeometry = true,
          NetworkAttributes = networkAttributeNames.ToList(),
          ResultFields = new Dictionary<NetworkSource, List<string>>() { { telcoDeviceNWSource, ["NEXTUNITID", "PARTITIONID"] },
            { telcoCircuit, ["LongTestField", "TextTestField", "DateTestField"] }}
        CircuitExportOptions circuitExportOptions = new CircuitExportOptions()
          IncludeDomainDescriptions = true,
          ResultOptions = resultOptions,
          ResultTypes = new List<ResultType> { ResultType.Circuit },
          ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
          SetAcknowledged = false,
          TraceConfiguration = traceConfiguration
        circuitManager.Export(circuitNames, circuitExportOptions, circuitExportPath);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
