ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / CircuitManager Class / Alter Method
The circuit to update.
Example
    Alter Method (CircuitManager)
    Updates a circuit row in the circuit table with the provided argument's values. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub Alter( _
       ByVal circuit As Circuit _
    public void Alter(
       Circuit circuit
    Parameters
    circuit
    Exceptions
    ExceptionDescription
    circuit is null.
    This operation cannot be invoked inside ArcGIS.Core.Data.Geodatabase.ApplyEdits or when an edit operation is in progress.
    A geodatabase-related exception has occurred.
    Example
    Alter an existing circuit in the utility network
    await QueuedTask.Run(() =>
      using (CircuitManager circuitManager = utilityNetwork.GetCircuitManager(telecomDomainNetwork))
        // Get the existing circuit
        Circuit circuit = circuitManager.GetCircuits(new CircuitFilter(["circuitName"])).First();
        // Update circuit name
        circuit.SetName(circuitNames.First());
        // Update start and stop locations
        circuit.SetStartLocation(new CircuitLocation(startElement));
        circuit.SetStopLocation(new CircuitLocation(stopElement));
        // Clear existing subcircuits
        circuit.SetSubcircuits(new List<Subcircuit>());
        // Apply the changes
        circuitManager.Alter(circuit);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
