ArcGIS.Core.Data.UtilityNetwork.Telecom Namespace / CircuitManager Class / Verify Method
The names of the circuits to verify.
The options that control how the circuits are verified.
Example
    Verify Method
    Verifies the specified circuits. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    circuitNames
    circuitVerifyOptions
    Return Value
    The verification result for each circuit.
    Exceptions
    ExceptionDescription
    The list of circuit names is empty, or circuitVerifyOptions specifies a spatial reference without enabling synthesized geometries.
    circuitNames or circuitVerifyOptions is null.
    This operation cannot be invoked inside ArcGIS.Core.Data.Geodatabase.ApplyEdits or when an edit operation is in progress.
    A geodatabase-related exception has occurred.
    Example
    Verify a circuit to check for inconsistencies in the utility network
    await QueuedTask.Run(() =>
      using (CircuitManager circuitManager = utilityNetwork.GetCircuitManager(telecomDomainNetwork))
        IReadOnlyList<CircuitVerifyResult> circuitVerifyResults = circuitManager.Verify(circuitNames, new CircuitVerifyOptions() { SynthesizeGeometries = true });
        // Iterate through the circuit verification results
        foreach (CircuitVerifyResult circuitVerifyResult in circuitVerifyResults)
          Console.WriteLine($"Circuit Name: {circuitVerifyResult.Name}, Geometry: {circuitVerifyResult.Geometry.ToJson()}, " +
                                  $"HasError: {circuitVerifyResult.HasError}, Message: {circuitVerifyResult.Message}");
    Requirements
    ArcGIS Pro version: 3.7 or higher.
