ArcGIS.Core.Parcels Namespace / ParcelUtilities Class / CalculateArcLengthFromRadiusCentralAngle Method
The arc radius. Specify a negative radius for a counter clockwise curve.
The central angle. Value is in decimal degrees.
    Calculates the arc length for an arc from a radius and central angle.
    Syntax
    Public Function CalculateArcLengthFromRadiusCentralAngle( _
       ByVal radius As Double, _
       ByVal centralAngle As Double _
    ) As Double
    public double CalculateArcLengthFromRadiusCentralAngle(
       double radius,
       double centralAngle
    Parameters
    radius
    centralAngle
    Return Value
    The calculated arc length.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
