| Name | Description | |
![]() ![]() | Instance | Gets the ParcelUtilities instance. |
The following tables list the members exposed by ParcelUtilities.
![]() | CalculateArcLengthFromRadiusCentralAngle | Calculates the arc length for an arc from a radius and central angle. |
![]() | CalculateArcLengthFromRadiusChordLength | Calculates the arc length for an arc from a radius and chord length. |
![]() | CalculateCentralAngleFromRadiusArcLength | Calculates the central angle for an arc from a radius and arc length. |
![]() | CalculateCentralAngleFromRadiusChordLength | Calculates the central angle for an arc from a radius and chord length. |
![]() | CalculateChordDirectionFromRadialDirectionChordLengthRadius | Calculates the chord direction for an arc from a radial direction, chord length and radius. |
![]() | CalculateChordDirectionFromTangentDirectionChordLengthRadius | Calculates the chord direction for an arc from a tangent direction, chord length and radius. |
![]() | CalculateChordLengthFromRadiusArcLength | Calculates the chord length for an arc from a radius and arc length.. |
![]() | CalculateChordLengthFromRadiusCentralAngle | Calculates the chord length for an arc from a radius and central angle. |
![]() | CalculateRadialDirectionFromChordDirectionChordLengthRadius | Calculates the radial direction for an arc from a chord direction, chord length and radius. |
![]() | CalculateRadialDirectionFromTangentDirectionRadius | Calculates the radial direction for an arc from a tangent direction and radius. |
![]() | CalculateRadiusFromArcLengthCentralAngle | Calculates the radius for an arc from an arc length and central angle. |
![]() | CalculateRadiusFromChordLengthCentralAngle | Calculates the radius for an arc from a chord length and central angle. |
![]() | CalculateTangentDirectionFromChordDirectionChordLengthRadius | Calculates the tangent direction for an arc from a chord direction, chord length and radius. |
![]() | CalculateTangentDirectionFromRadialDirectionRadius | Calculates the tangent direction for an arc from a radial direction and radius. |
![]() | ConvertNorthAzimuthDecDegToNorthAzimuthDMS | Converts a value in North Azimuth decimal degrees to a string in North Azimuth DIMS. |
![]() | ConvertNorthAzimuthDecDegToQuadrantBearingDMS | Converts a value in North Azimuth decimal degrees to a quadrant bearing in DIMS. |
![]() | ConvertNorthAzimuthDMSToNorthAzimuthDecDeg | Converts a value in North Azimuth DMS to North Azimuth decimal degrees. |
![]() | ConvertQuadrantBearingDMSToNorthAzimuthDecDeg | Converts a quadrant bearing in DMS to a value in North Azimuth decimal degrees. |
![]() | SimplifyShapeByTangentSegments | Overloaded. |
