ArcGIS.Core.Parcels Namespace / ParcelUtilities Class / CalculateChordLengthFromRadiusArcLength Method
The arc radius. Specify a negative radius for a counter clockwise curve.
The arc length.
    Calculates the chord length for an arc from a radius and arc length..
    Syntax
    Public Function CalculateChordLengthFromRadiusArcLength( _
       ByVal radius As Double, _
       ByVal arcLength As Double _
    ) As Double
    public double CalculateChordLengthFromRadiusArcLength(
       double radius,
       double arcLength
    Parameters
    radius
    arcLength
    The arc length.
    Return Value
    The calculated chord length. The chord length will be returned as negative value indicating it is a major arc if appropriate.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
