Public Function CalculateRadialDirectionFromChordDirectionChordLengthRadius( _ ByVal chordDirection As Double, _ ByVal chordLength As Double, _ ByVal radius As Double _ ) As Double
public double CalculateRadialDirectionFromChordDirectionChordLengthRadius( double chordDirection, double chordLength, double radius )
Parameters
- chordDirection
- The chord direction. Value is in North azimuth decimal degrees.
- chordLength
- The chord length of the arc. Specify a negative value for a major arc.
- radius
- The arc radius. Specify a negative radius for a counter clockwise curve.
Return Value
The calculated radial direction in North azimuth decimal degrees.
