ArcGIS.Core.Parcels Namespace / ParcelUtilities Class / CalculateTangentDirectionFromRadialDirectionRadius Method
The radial direction. Value is in North azimuth decimal degrees.
The arc radius. Specify a negative radius for a counter clockwise curve.
    Calculates the tangent direction for an arc from a radial direction and radius.
    Syntax
    Public Function CalculateTangentDirectionFromRadialDirectionRadius( _
       ByVal radialDirection As Double, _
       ByVal radius As Double _
    ) As Double
    public double CalculateTangentDirectionFromRadialDirectionRadius(
       double radialDirection,
       double radius
    Parameters
    radialDirection
    radius
    Return Value
    The calculated tangent direction in North azimuth decimal degrees.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
