ArcGIS.Core.Parcels Namespace / ParcelUtilities Class / CalculateCentralAngleFromRadiusChordLength Method
The arc radius. Specify a negative radius for a counter clockwise curve.
The chord length. Specify a negative value for a major arc.
    Calculates the central angle for an arc from a radius and chord length.
    Syntax
    Public Function CalculateCentralAngleFromRadiusChordLength( _
       ByVal radius As Double, _
       ByVal chordLength As Double _
    ) As Double
    public double CalculateCentralAngleFromRadiusChordLength(
       double radius,
       double chordLength
    Parameters
    radius
    chordLength
    Return Value
    The central angle. Value is in decimal degrees.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
