ArcGIS.Core.Parcels Namespace / ParcelUtilities Class / CalculateRadiusFromArcLengthCentralAngle Method
The arc length.
The central angle. Value is in decimal degrees.
    Calculates the radius for an arc from an arc length and central angle.
    Syntax
    Public Function CalculateRadiusFromArcLengthCentralAngle( _
       ByVal arcLength As Double, _
       ByVal centralAngle As Double _
    ) As Double
    public double CalculateRadiusFromArcLengthCentralAngle(
       double arcLength,
       double centralAngle
    Parameters
    arcLength
    The arc length.
    centralAngle
    Return Value
    The calculated arc radius.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
