ArcGIS.Core.Parcels Namespace / ParcelUtilities Class / CalculateTangentDirectionFromChordDirectionChordLengthRadius Method
The chord direction. Value is in North azimuth decimal degrees.
The chord length of the arc. Specify a negative value for a major arc.
The arc radius. Specify a negative radius for a counter clockwise curve.
    Calculates the tangent direction for an arc from a chord direction, chord length and radius.
    Syntax
    Public Function CalculateTangentDirectionFromChordDirectionChordLengthRadius( _
       ByVal chordDirection As Double, _
       ByVal chordLength As Double, _
       ByVal radius As Double _
    ) As Double
    public double CalculateTangentDirectionFromChordDirectionChordLengthRadius(
       double chordDirection,
       double chordLength,
       double radius
    Parameters
    chordDirection
    chordLength
    radius
    Return Value
    The calculated tangent direction in North azimuth decimal degrees.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
