ArcGIS.Core.Parcels Namespace / ParcelUtilities Class / CalculateRadialDirectionFromTangentDirectionRadius Method
The tangent direction. Value is in North azimuth decimal degrees.
The arc radius. Specify a negative radius for a counter clockwise curve.
    Calculates the radial direction for an arc from a tangent direction and radius.
    Syntax
    Public Function CalculateRadialDirectionFromTangentDirectionRadius( _
       ByVal tangentDirection As Double, _
       ByVal radius As Double _
    ) As Double
    public double CalculateRadialDirectionFromTangentDirectionRadius(
       double tangentDirection,
       double radius
    Parameters
    tangentDirection
    radius
    Return Value
    The calculated radial direction in North azimuth decimal degrees.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
