Public Function CalculateChordLengthFromRadiusCentralAngle( _ ByVal radius As Double, _ ByVal centralAngle As Double _ ) As Double
public double CalculateChordLengthFromRadiusCentralAngle( double radius, double centralAngle )
Parameters
- radius
- The arc radius. Specify a negative radius for a counter clockwise curve.
- centralAngle
- The central angle. Value is in decimal degrees.
Return Value
The calculated chord length. If the central angle is more than 180 degrees, then the chord length will be
returned as a negative value indicating it is a major arc.
