ArcGIS.Core.Parcels Namespace / ParcelUtilities Class / CalculateChordDirectionFromRadialDirectionChordLengthRadius Method
The radial direction. Value is in North azimuth decimal degrees.
The chord length of the arc. Specify a negative value for a major arc.
The arc radius. Specify a negative radius for a counter clockwise curve.
    Calculates the chord direction for an arc from a radial direction, chord length and radius.
    Syntax
    Public Function CalculateChordDirectionFromRadialDirectionChordLengthRadius( _
       ByVal radialDirection As Double, _
       ByVal chordLength As Double, _
       ByVal radius As Double _
    ) As Double
    public double CalculateChordDirectionFromRadialDirectionChordLengthRadius(
       double radialDirection,
       double chordLength,
       double radius
    Parameters
    radialDirection
    chordLength
    radius
    Return Value
    The calculated chord direction in North azimuth decimal degrees.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
