ArcGIS.Desktop.Editing.COGO Namespace / BaseCurveDefinition Class / CanCalculateCentralAngle Method
    Determines if the central angle can be calculated from the curve definition.
    Syntax
    Public Function CanCalculateCentralAngle() As Boolean
    public bool CanCalculateCentralAngle()
    Return Value
    True if the curve definition has the appropriate values to calculate the central angle.
    Remarks
    The central angle can be calculated if the curve definition contains a Radius and a ChordLength or a Radius and an ArcLength.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
